but it is pretty much just the code from datassist:
I ran the extension on other pages outside of my admin folder ( this one is inside of it) and it came up without a problem. The only pages that it seems to have a problem coming up on are the insert and update pages.
<?php require_once('../Connections/ua_inventory.php'); ?>
<?php require_once("../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_ua_inventory, $ua_inventory);
$query_rsInv = "SELECT * FROM products";
$rsInv = mysql_query($query_rsInv, $ua_inventory) or die(mysql_error());
$row_rsInv = mysql_fetch_assoc($rsInv);
$totalRows_rsInv = mysql_num_rows($rsInv);
// WA Application Builder Insert
if (isset($_POST["Insert_x"])) // Trigger
$WA_connection = $ua_inventory;
$WA_table = "products";
$WA_sessionName = "WADA_Insert_products";
$WA_redirectURL = "products_Detail.php";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_indexField = "invID";
$WA_fieldNamesStr = "qty|manufacturer|model|category|subcategory|description|detail|color|size|msrp|sale|dump|map|sap|img|notes";
$WA_fieldValuesStr = "".((isset($_POST["qty"]))?$_POST["qty"]:"") ."" . "|" . "".((isset($_POST["manufacturer"]))?$_POST["manufacturer"]:"") ."" . "|" . "".((isset($_POST["model"]))?$_POST["model"]:"") ."" . "|" . "".((isset($_POST["category"]))?$_POST["category"]:"") ."" . "|" . "".((isset($_POST["subcategory"]))?$_POST["subcategory"]:"") ."" . "|" . "".((isset($_POST["description"]))?$_POST["description"]:"") ."" . "|" . "".((isset($_POST["detail"]))?$_POST["detail"]:"") ."" . "|" . "".((isset($_POST["color"]))?$_POST["color"]:"") ."" . "|" . "".((isset($_POST["size"]))?$_POST["size"]:"") ."" . "|" . "".((isset($_POST["msrp"]))?$_POST["msrp"]:"") ."" . "|" . "".((isset($_POST["sale"]))?$_POST["sale"]:"") ."" . "|" . "".((isset($_POST["dump"]))?$_POST["dump"]:"") ."" . "|" . "".((isset($_POST["map"]))?$_POST["map"]:"") ."" . "|" . "".((isset($_POST["sap"]))?$_POST["sap"]:"") ."" . "|" . "".((isset($_POST["img"]))?$_POST["img"]:"") ."" . "|" . "".((isset($_POST["notes"]))?$_POST["notes"]:"") ."";
$WA_columnTypesStr = "none,none,NULL|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL|',none,''|',none,''";
$WA_connectionDB = $database_ua_inventory;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<head>
<title>Insert products</title>
<link href="../WA_DataAssist/styles/Refined_Pacifica.css" rel="stylesheet" type="text/css" />
<link href="../WA_DataAssist/styles/Arial.css" rel="stylesheet" type="text/css" />
</head>
<body>
<div class="WADAInsertContainer">
<form action="products_Insert.php" method="post" name="WADAInsertForm" id="WADAInsertForm">
<div class="WADAHeader">Insert Record</div>
<div class="WADAHorizLine"><img src="../WA_DataAssist/images/_tx_.gif" alt="" height="1" width="1" border="0" /></div>
<table class="WADADataTable" cellpadding="0" cellspacing="0" border="0">
<tr>
<th class="WADADataTableHeader">invID:</th>
<td class="WADADataTableCell"></td>
</tr>
<tr>
<th class="WADADataTableHeader">qty:</th>
<td class="WADADataTableCell"><input type="text" name="qty" id="qty" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">manufacturer:</th>
<td class="WADADataTableCell"><input type="text" name="manufacturer" id="manufacturer" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">model:</th>
<td class="WADADataTableCell"><input type="text" name="model" id="model" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">category:</th>
<td class="WADADataTableCell"><input type="text" name="category" id="category" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">subcategory:</th>
<td class="WADADataTableCell"><input type="text" name="subcategory" id="subcategory" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">description:</th>
<td class="WADADataTableCell"><input type="text" name="description" id="description" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">detail:</th>
<td class="WADADataTableCell"><input type="text" name="detail" id="detail" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">color:</th>
<td class="WADADataTableCell"><input type="text" name="color" id="color" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">size:</th>
<td class="WADADataTableCell"><input type="text" name="size" id="size" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">msrp:</th>
<td class="WADADataTableCell"><input type="text" name="msrp" id="msrp" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">sale:</th>
<td class="WADADataTableCell"><input type="text" name="sale" id="sale" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">dump:</th>
<td class="WADADataTableCell"><input type="text" name="dump" id="dump" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">map:</th>
<td class="WADADataTableCell"><input type="text" name="map" id="map" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">sap:</th>
<td class="WADADataTableCell"><input type="text" name="sap" id="sap" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">img:</th>
<td class="WADADataTableCell"><input type="text" name="img" id="img" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">notes:</th>
<td class="WADADataTableCell"><input type="text" name="notes" id="notes" value="" size="32" /></td>
</tr>
</table>
<div class="WADAButtonRow">
<table class="WADADataNavButtons" border="0" cellpadding="0" cellspacing="0">
<tr>
<td class="WADADataNavButtonCell" nowrap="nowrap"><input type="image" name="Insert" id="Insert" value="Insert" alt="Insert" src="../WA_DataAssist/images/Pacifica/Refined_insert.gif" /></td>
<td class="WADADataNavButtonCell" nowrap="nowrap"><a href="products_Results.php" title="Cancel"><img border="0" name="Cancel" id="Cancel" alt="Cancel" src="../WA_DataAssist/images/Pacifica/Refined_cancel.gif" /></a></td>
</tr>
</table>
<input name="WADAInsertRecordID" type="hidden" id="WADAInsertRecordID" value="" />
</div>
</form>
</div>
</body>
</html>
mysql_free_result($rsInv);
