Printing off shows all html
Thread began 3/15/2011 1:59 am by J7HNW | Last modified 3/15/2011 1:22 pm by Jason Byrnes | 1085 views | 4 replies |
J7HNW
I am using HTML Editor in Univeral E Mail to send out price increase letters to a database.
Please see attached
1. The font is set to Tahoma but has not formatted correctly on the email (see screenshot ) > If you view the HTML Code you will see this has been set to Tahoma
2. When you print off the e mail - all the HTML TAGS show on the print off. CAn I stop this form happening so the e mail arrived in a printable format ?
How can I Solve these please
Thank you in advance
Webassist.zip
if you look closely at the html it is not properly formatted.
for example, I see:
<SPAN style=""font-family: " tahoma;\?>
there is an extra quote in this and the style is not inside the first set of quotes, it should be:
<SPAN style="font-family: tahoma;">
I see that for all of the styles on this page.
J7HNW
Thanks but...
Thanks Jason - but this is all being formatted by HTML Editor.
Why is it not formatting properly then ? My client says he typed in Tahoma and sent the mail which came through as shown.
When you print it off - all HTML shows on the page. Is this a bug then on the latest version of HTML Editor ?
the issue was caused by the magic-quotes_gpc setting being turned on in the php.ini file.
we resolved by using stripslashes() on the form output.
to prevent the problem in the future I recommended using the following script at line 1 of the form page:
if($_SERVER["REQUEST_METHOD"] == "POST")     {
    foreach(
$_POST as $key => $val) {
$_POST[$key] = stripslashes($val);
