var Departure Location_Spry = new Spry.Widget.ValidationTextField("Departure Location
Thread began 3/14/2011 2:21 pm by SPT | Last modified 3/14/2011 3:45 pm by SPT | 2002 views | 2 replies |
SPT
Dreamweaver gives this message in code view:
There is an syntax error on line 334. Code hinting may not work until you fix this error.
Line 334 -
var Departure Location_Spry = new Spry.Widget.ValidationTextField("Departure Location_Spry", "none", { isRequired:false , validateOn:["blur"]});
Page built just to test the form without any thing else on the page to see why it keeps happening.
contact-form.php
Also whenever I use form builder it cuts off the space at the bottom of the page. squaring off my backgrounds.
examples:
VacationInformation.php
this error is caused by using a name with spaces for te departre location form field:
<input type="text" onblur="hideServerError('Departure Location_ServerError');" tabindex="4" class="formTextfield_Medium" value="" name="Departure Location" id="Departure Location">
spaces are not valid in form field names.
for the issue with the bottom of the page, in the webassist/forms/fd_newfromblank_default/Datepicker/css/jquery-ui-1.7.1.custom.css file
change:
.ui-helper-clearfix { display: inline-block; }
.ui-helper-clearfix { display: none; }
SPT
Thank you - Got it working now!
