Dreamweaver CS4 Crashes With V3.0.1
Hello,
After upgrading to V3.0.1 HTML Editor Dreamweaver CS4 running on a MAC will crash when you choose to insert HTML Editor.
Do you have any suggestions as to what this might be caused by?
Many Thanks
Hello,
Many Thanks
Delete the Dreamweaver Cache file from the users configuration folder:
Thanks that seems to have fixed the issue.
However I have 2 question about customization.
I want the editor on the site to be very basic, no tools, etc
1. I have removed the tools array, but I also do not want to show "body p" below the editor when the user starts typing can this be disabled?
2. Can the tool bar default to be minimised and same as if you click the arrow to hide?
1) I'm not sure i totally understand what you mean by:
can you send a screen shot that demonstrates the issue?
2) add the following line:
$CKEditor_config["toolbarStartupExpanded"] = false;
just before this one:
$CKEditor_config["toolbar"] = array(
Hello,
Please see the following attachment showing when the Body and P Tags appear.
My question is can they be disabled to not show as they confuse the user.
Many Thanks
CKEditor does not offer a way to disable the tag selector.
you can try adding the following style to your page:
<style>
#cke_bottom_ContentValue { display:none; }
</style>
I have tested this in firefox and safari, but cant guarantee it will work across all browsers.
