error ToJSONString
CSS Menu Writer error when I try to url dynamics gives me this error and I can not do anything like this problem
I have problems with CSS Menu Writer extension gives me error when I put toJSONString dynamic url that its implementation does not automatically generate the database you need I can give a solution for its extension to use dynamic url.
its length is not much that does not work, to eliminate the boy not to install more.
can you send a copy of the menu.php page you are adding the menu to and the CSSMenuWriter folder in a zip archive so I can examine the code.
sent you the zip review it because I can not do anything for me because of this error is of vital essence to use dynamic menu
Problem solved, so that part does not have support when they received no effective response by its share of technical
The problem is another extension Wigget Weather is changing the route of some weassist extensions.
Goyo very bad especially the Spanish media.
OK, I'm happy to hear you found the cause of the issue.
