Manage Relational Table
Thread began 3/13/2011 6:08 am by Cologne | Last modified 3/14/2011 2:55 pm by Jason Byrnes | 866 views | 4 replies |
Cologne
how can I use "Manage Relational Table" when I first insert data into my table? Cause then I dont know the foreign key of my dataset. Wehn I try to use a variable like "$insertedRow" that I create with mysql_insert_id() I get the red asterix :-(
I also tried to generate a session (mysql_insert_id()) after inserting the data.
And then I tried to insert a new product into the database, then get it with a recordset. and then try to manage that relation, but it still does not work. I always get that red asterix, doesnt matter what, I choose as KEY with the lightning flash.
AND I cant re-EDIT that behavior.
I NEED HELP!
HOw can I do that?
Denis
In the data Assist Insert record behavior, the session variable section allows you to store the ID of the inserted record to a session variable. See the attached screen shot.
use that session variable in the manage relational table behavior.
If you edited the code for the manage relational table behavior by hand, it will cause the behavior not to show on the server behaviors panel, you will need to delete the behavior code, then reapply it.
Cologne
cool, I will try that, and give you a feedback!
Cologne
cool, this works, so I dont need to create another session :-)
thanks!
You're welcome.
