Possible to use a Hotspot in where clause?
Say I've got a map with hotspots on it. I't easy to direct them to seperate pages, but can I use the hotspot ID (or something) in the where clause on the results page?
Thanks much.
Thanks much.
Yes, you can use data assist search to pass in a dynamic value to use in the where clause.
Excellent. Might there be a tutorial somewhere?
See the "Working with DataAssist Search" tutorial on the data assist support page:
dataassist/
Hmm, I looked and found no relevant info there. Any ideas?
You would pass a value as part of the url associated with each hotspot so hotspot 1 would link to "yourpage.php?value=1", hotspot 2 would link to "yourpage.php?value=2" and so on
You would then use the value to filter the recordset results.
