Image Upload - uploads to Server but not showing up in Results
Thread began 3/09/2011 2:06 am by pete | Last modified 3/09/2011 1:57 pm by Jason Byrnes | 849 views | 3 replies |
pete
[SuperSuite; CSSFormBuilder 2]
I've created a form that allows a client to populate a Results page. The update/insert functions work fine. However, the image does not show up on the results page.
I'll paste my code here in case it's of use. I'm pretty sure that I'm just missing a dynamic variable of some sort...
Thx,
Pete
BEGIN CODE PASTE:
<?php require_once('Connections/slideshowAdmin.php');?>
<?php require_once('Connections/friends.php'); ?>
<?php require_once("WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php require_once("webassist/file_manipulation/helperphp.php"); ?>
<?php require_once( "WA_SecurityAssist/Helper_PHP.php" ); ?>
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "images/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "2",
'ResizeWidth' => "200",
'ResizeHeight' => "120",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if($_SERVER["REQUEST_METHOD"] == "POST"){
WA_DFP_UploadFiles("WA_UploadResult1", "logo", "0", "", "true", $WA_UploadResult1_Params);
// WA Application Builder Insert
if (isset($_POST["Insert_x"])) // Trigger
$WA_connection = $friends;
$WA_table = "links";
$WA_sessionName = "WADA_Insert_links";
$WA_redirectURL = "links_Results_Admin.php";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = true;
$WA_indexField = "id";
$WA_fieldNamesStr = "name|url|desc|imagename";
$WA_fieldValuesStr = "".((isset($_POST["name"]))?$_POST["name"]:"") ."" . "|" . "".((isset($_POST["url"]))?$_POST["url"]:"") ."" . "|" . "".((isset($_POST["desc"]))?$_POST["desc"]:"") ."" . "|" . "".((isset($_POST["imagename"]))?$_POST["imagename"]:"") ."";
$WA_columnTypesStr = "',none,''|',none,''|',none,''|',none,''";
$WA_connectionDB = $database_friends;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
<div class="WADAInsertContainer">
<form action="links_Insert.php" method="post" enctype="multipart/form-data" name="WADAInsertForm" id="WADAInsertForm">
<div class="WADAHorizLine"><img src="WA_DataAssist/images/_tx_.gif" alt="" height="1" width="1" border="0" /></div>
<table class="WADADataTable" cellpadding="0" cellspacing="0" border="0">
<tr>
<th class="WADADataTableHeader">Company Name:</th>
<td class="WADADataTableCell"><input type="text" name="name" id="name" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Company URL: </th>
<td class="WADADataTableCell"><input type="text" name="url" id="url" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Company Description: </th>
<td class="WADADataTableCell"><input type="text" name="desc" id="desc" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Logo Upload: </th>
<td class="WADADataTableCell"><input name="logo" type="file" size="0
" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Logo Filename: </th>
<td class="WADADataTableCell"><input type="text" name="imagename" id="imagename" value="" size="32" /></td>
</tr>
</table>
<div class="WADAButtonRow">
<table class="WADADataNavButtons" border="0" cellpadding="0" cellspacing="0">
<tr>
<td class="WADADataNavButtonCell" nowrap="nowrap"><input type="image" name="Insert" id="Insert" value="Insert" alt="Insert" src="WA_DataAssist/images/Pacifica/Refined_insert.gif" /></td>
<td class="WADADataNavButtonCell" nowrap="nowrap"><a href="links_Results.php" title="Cancel"><img border="0" name="Cancel" id="Cancel" alt="Cancel" src="WA_DataAssist/images/Pacifica/Refined_cancel.gif" /></a></td>
</tr>
</table>
<input name="WADAInsertRecordID" type="hidden" id="WADAInsertRecordID" value="" />
</div>
</form>
</div>
</body>
</html>
END CODE PASTE:
see the "How to apply Digital File Pro to DataAssist Insert and Update pages" tutorial in the how to section of the Data Assist support page.
dataassist/
pete
Got it working on the Insert page; still having trouble with the Update page. I'll keep working on it as I think I'm on the right track.
Thanks, Jason,
Pete
what is the issue you are having on the update page?
if you need further assistance, add the the update php page to a zip archive and attach the zip file to your reply.
