Warning: mysql_free_result(): error message
Thread began 3/08/2011 6:45 am by Sally | Last modified 3/08/2011 8:12 am by Jason Byrnes | 5528 views | 3 replies |
Sally
When I go to my PG login page there is an error message at the top which says:
Warning: mysql_free_result(): supplied argument is not a valid MySQL result resource in /data/25/2/98/45/2424045/user/2657060/htdocs/spyglasscondos/powergallery/admin_gallery/global.php on line 37
On global.php line 37 is the second to the last line in the following command:
require_once("images/installed.png");
//PowerGallery version
$wa_settings['pg_version'] = '1.2.0';
mysql_free_result($result);
I've tried re-uploading installed.png but I still get the error. Not sure what's going on as nothing changed since about a month ago. When I also had this error and Neilo gave me a new copy of the image which fixed the problem then. I've checked the server and the new copy is up there.
Thanks for your help.
change:
Sally
That did it. Thank you, Jason.
you're welcome.
