Undefined Variable when adding user
Thread began 3/08/2011 6:19 am by saf01 | Last modified 3/09/2011 7:09 am by Jason Byrnes | 2469 views | 5 replies |
saf01
Im using lastest wamp with php 5.2.11 and 5.3.5 localhost (tested with both php versions) and magic_quotes disabled. Ive successfully installed PowerCMS without any problems using DWCS3.
So in the admin, when I add a user I get the following message:
Undefined variable: $totalRows_contents in ..\manage_users.php on line 246
Should $totalRows_contents be $row_cmscontents or something else.
Please help. Cheers
edit line 246 of the manage_users.php page:
<td><?php if($totalRows_contents ) {
<td><?php if($totalRows_cmscontents ) {
saf01
Thats fixed it. Thx.
I have another question.
When i add content areas via admin in my page as meta-title, meta-description, meta-keywords I get the Page Optimization link appearing which is fine.
So how do I add these areas to my page - do i add php code in my php page - as my page optimisation doesnt pick up the title, description or keywords.
Please help.
the page optimization will not happen automaticly, you need to add the meta tags and use the WebAssist -> CMS -> Insert Comment From Power CMS to addd the meta tag information.
go to WebAssist -> CMS -> Insert Comment From Power CMS, and select content then select the meta key word content area.
this will add code to the page similar to:
<?php echo WA_getCMSContent($database_PowerCMSConnection$PowerCMSConnection'testing''meta-keywords'); ?>
add that to the content of a key word meta tag.
<meta name="keywords" content="<?php echo WA_getCMSContent($database_PowerCMSConnection$PowerCMSConnection'testing''meta-keywords'); ?>" />
do the same for the description and title:
<meta name="description" content="<?php echo WA_getCMSContent($database_PowerCMSConnection$PowerCMSConnection'testing''meta-description'); ?>" />
<title>
<?php echo WA_getCMSContent($database_PowerCMSConnection$PowerCMSConnection'testing''meta-title'); ?>Untitled Document
</title>
bear in mind, my example is using a content area named testing, your code may be different.
saf01
Thx Jason. This is cool - appreciated.
you're welcome.
