Themes not changing
After selecting from standard to crazy theme, PS defaulted back to standard layout, then in design mode does not allow me to change to new theme. This is in 57 build.
Regards
Russ
Regards
Russ
Is it possible that you were editing the Default theme at the time? While editing a theme it is locked in the session to only view that theme even though everyone else will see the theme you selected.
I'll try to reproduce the problem, but that might be the explanation.
Looks like it's an issue with safari, works normal in Firefox
Russ
Mmm, seem to have the same problem with Firefox now.
Russ
I restarted my laptop (macbookpro)
I login to the store manager then update the theme, it changes in manager and on the public side, shows the update, however as soon as you select any other page from that moment on it revert to the standard blue theme. If you try and change the theme in manager it does nothing.
Hope that explains it better.
Russ
Yes... it seems to only happen when you get the "unsaved theme" message and click "Continue". I was able tor reproduce the problem and get it fixed... thanks for the feedback.
