Recordset Navigation with Repeat Selection...
I've got a page that uses the Accordion widget to display data dynamically in a repeat region. Within the Accordion region I've added a repeat selection around a dynamic image to enable the display of a series of 124 images from a recent event. I've been able to display all of the images on the page without a problem. To enable display of groups of 8 images, I have to remove the Repeat Selection and add it back in - changing the Repeat Selection Server Behavior on the page inserts code that throws a syntax error. No problem - I just remove and reapply the Server Behavior. The problem I've encountered is that when I insert the Dreamweaver native Recordset Navigation (the documentation says that the Repeat Selection works with this) and then view my page, the only image displayed is the first record and the Next/Last navigation does nothing.
Have you seen this phenomenon before, and do you have a workaround for it?
Thanks! I look forward to your reply!
