Bug report Data Assist 2.0.8
Thread began 3/03/2011 9:04 pm by fseverino268200 | Last modified 3/04/2011 8:43 am by Jason Byrnes | 1277 views | 3 replies |
fseverino268200
I'm building a cms that is in a directory called admin, i.e. /site root/admin.
all my insert and update behaviors are having a weird redirect issue, all the scripts redirect to a file in the same directory, but instead of going to the file in the same directory I'm getting the following in my browser address bar.
http://sitename.com/home/username/public_html/admin/page_to_redirect_to.php
( info, I changed the real site name and user name for security.)
The insert/update works and enters the data in the db but the redirect fails.
I've never seen this problem when using the extension in the root directory and also when I remove the data assist insert/update code and use Dreamweavers insert/update code it works perfectly.
TIA for any insight on this issue.
-Frank
Dave BuchholzBeta Tester
This thread has the answer to your issue http://www.webassist.com/forums/showthread.php?t=17866 look for Issue with redirects after insert/update in 2.0.8 in the sticky threads at the top of this forum.
fseverino268200
Thanks much
OK, thanks much for the info..................
I downloaded the new library file and put it in the helpers directory.
-Frank
There is also a fix for this issue in the Known Issues section of the data assist download center page.
