Attachment Problems
Thread began 3/02/2011 6:19 pm by rob293221 | Last modified 3/07/2011 10:58 am by Jason Byrnes | 1305 views | 5 replies |
rob293221
Attachment Problems
Hello,
I am having an issue with the attachment aspect of UE. On the test emails I receive it shows the file name that was added to the file field but not attachment.
URL: application.php
Any advice would be appreciated!
I am using UE 4.0.1
Files attached.
UEthrottle.zip
for a file to upload, the encoding type of the form must be sret to multipart/form-data.
change the form tag to;
<form  action="" method="post" enctype="multipart/form-data" name="application" id="application" onsubmit="WAValidateRQ(document.application.Name,'- Please enter your name.',document.application.Name,0,false,'text');WAValidateRQ(document.application.Email,'- Please enter your email address.',document.application.Email,0,false,'text');WAValidateRQ(document.application.Phone_Number,'- Please enter your phone number.',document.application.Phone_Number,0,false,'text');WAValidateRQ(document.application.Date_of_Birth,'- Please enter your date of birth.',document.application.Date_of_Birth,0,false,'text');WAAlertErrors('The following errors were found','Correct invalid entries to continue',true,false);return document.MM_returnValue">
rob293221
Thank you, that did the trick.
I found another issue that I can use some help with. When the email arrives, it does not display the "From" field. It is either blank, or states Unknown. Any ideas?
Thanks again for all your help!
Try leaving the from name blank, setting the from email address to a hard coded address for your domain, then set the Reply to address option to use the email address form element.
rob293221
Worked like a charm! Thank you!
you're welcome.
