Delete Record and Order History
When a user Deletes a record using the stock behavior code, does it also delete instances of that record from the Order Details table, or does it just remove it from future access??
Thanks,
Mike
Thanks,
Mike
No, you need to add another delete record behavior to delete the records from the order details table.
Thanks Jason.
In this case I obviously want the Order history to remain intact. Wanted to make sure it would -- suspected that was the case.
Later. . .
