registration page if duplicate, goto???
Thread began 3/02/2011 8:06 am by tonyk1973423186 | Last modified 3/03/2011 8:29 am by Jason Byrnes | 1234 views | 5 replies |
tonyk1973423186
question.
i'm thinking of purchasing this extension, but i'm also looking to use it for insert or update pages too.
there is a screenshot for registration page, where if duplicate, go to:??? you can have mulitple columns to have this rule applied, correct?
as of now, dreamweaver only lets you run one check username in the server behaviors, you cannot have mulitple columns with this rule.
so i know this is a login and registration extension. but can i also use this for insert page or update page where if there are multiple columns with duplicate info, it will redirect???
or if this can't do it, does anyone know, thanks
security assist uses the Dreamweaver Check new user name behavior for this, it has the same one column limitation.
you could do this using a recordset and the Server Validation beahviors in Form Toolkit though.
Create a recrdset that will filter the email column on the email form element, this will create a variable named:
$totalRows_<recordset_name>
where <recordset_name> name is the name of the recordset
create a second recordset to filter the other column on the coresponding form element.
when adding the server validation behavor, choose numeric validation, for the server variable, enter:
<recordset_name>
set the minimum number to -1 and the max to 0
add a second numeric validation for the second recordset using the <recordset_name> variable for that recordset.
this will pass validation only if those two recordsets are empty.
tonyk1973423186
formtool kit, is that only for PHP?
i notice requirement is php and not for ASP/VB
thanks
Yes, form toolkit is for PHP only, we do not have a solution for this that will work in ASP.
tonyk1973423186
thank you for the quick response, i do have one more question about security assist with cookies.
I created a login page. has just username and password.
once logged in, the following page currently i am passing a cookie by the username field. So it will say "Welcome Username"
Does security assist or any of your other extensions allow, if i login with username field, the following page can pull from the table their first and last name, displaying "Welcome Joe Smith" instead of "Welcome jsmith (username)"
thanks for the assistances
on the login page, double click the Security Assist authenticate user behaivor. click next till you get to the third screen. On the third screen you can select database columns to store in a session variable on login, select the first and last name columns.
you can now use these session variables to how the users first and last name after they login.
