File upload problem in SS CMS
Hello, I'm trying to upload large files into the CMS repository of a Site Sculptor site. Is there a size limit on the files and can I override it please?
upload file size limits are set in the PHP.ini file. see the following page for details on the settings that effect file upload size:
wap_upload.asp?page=php2
contact your host to see if there is a way these settings can be altered.
I have come across this before and used a php.ini file to override the server set limit to good effect but I don't know which folder to put the file in to achieve this.
contact you're host, they will be able to assist you with this.
