Dynamic Plugins with P-CMS admin
Thread began 2/27/2011 7:25 pm by MikeH | Last modified 2/28/2011 5:29 am by Dave Buchholz | 1251 views | 3 replies |
MikeH
Hi
I have a P-CMS admin page created from the admin template, When I try to add a dynamic plugin I get a syntax error thrown in the Framwewrok code added.
Now I have also tried a dynamic plugin with a plain php page and no issues weird thing is the code is identiacl and no errors.
Is there something in the P.CMS admin that is incompatible?
Please note this is a dynamic polugin not a Static one which works fine.
Mike
For this example the included page is a blank PHP page.
(Syntax error around Line 8)
require_once( "../webassist/framework/library.php" );
require_once(
"../webassist/framework/framework.php" );
require_once( "../WA_SecurityAssist/Helper_PHP.php" );
if(
true){
// WebAssist Framework Builder Dynamic Plug-in: $WA_gallery_test_2_1298852612389
switch(isset(action)?action:""){
  case
"edit":
$WA_gallery_test_2_1298852612389 = new WA_Include("gallery_test_2.php");
   break;
  default:
   break;
 if(isset(
$WA_gallery_test_2_1298852612389)){
  require(
$WA_gallery_test_2_1298852612389->BaseName);
$WA_gallery_test_2_1298852612389->Initialize(true);
// End: WebAssist Framework Builder Dynamic Plug-in: $WA_gallery_test_2_1298852612389
 require_once(
"../WA_Globals/WA_Globals.php" ); ?>
require_once('../Connections/PowerCMSConnection.php'); ?>
require_once( "../WA_CMS/WA_CMS.php" ); ?>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml"><!-- InstanceBegin template="/Templates/admin.dwt.php" codeOutsideHTMLIsLocked="false" -->
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<!-- InstanceBeginEditable name="doctitle" -->
<title><?php echo($WAGLOBAL_Site_Name); ?> - [page]</title>
<!-- InstanceEndEditable -->
<style type="text/css" media="all">
@import url('css/admin.css');
</style>
<!--[if IE]>
<style type="text/css">
/* The proprietary zoom property gives IE the hasLayout property which addresses several bugs. */
#outerWrapper #contentWrapper #content {
  zoom: 1;
</style>
<![endif]-->
<!-- InstanceBeginEditable name="head" -->
<?php echo((isset($WA_gallery_test_2_1298852612389))?$WA_gallery_test_2_1298852612389->Head:""?>
<script type="text/javascript"  src="../js/mootools-core.js"></script>
<script type="text/javascript"  src="../js/mootools-more.js"></script>
<script type="text/javascript"  src="../CSSMenuWriter/cssmw/menu.js"></script>
@import url("CSSMenuWriter/cssmw/menu.css");
</style>
<!-- InstanceBeginEditable name="menu_ie" -->
<!--[if lte IE 6]>
@import url("CSSMenuWriter/cssmw/menu_ie.css");
</style>
@import url("css/admin_ie.css");
</style>
img, div, ul, li, span, a {
  behavior: url("CSSMenuWriter/cssmw_images/iepngfix.htc");
</style>
<![endif]-->
</head>
<body>
<div id="outerWrapper">
  <div id="header">
   <div class="left">
     <a href="index.php"><img  src="../images/logo.png" alt="Content Management" /></a>
    </div>
    <div class="right">
 <a href="contents_search.php">Advanced Search</a> | <a href="users_login.php?logout=1">Log Out</a></div>
  </div>
  <div id="topNavigation">
     <div id="searchBox">
      <form  action="contents_results.php" method="get"  id="WADASearchForm">
       <p>
       <input type="text" name="S_Keyword" id="S_Keyword" value="" />
       <input type="submit" name="Search" id="Search" value="Search" alt="Search" class="btn" />
       </p>
    </form>
  </div>
    <?php require_once("../CSSMenuWriter/cssmw/menu.php"); ?>
  </div>
  <div id="contentWrapper"><!-- InstanceBeginEditable name="LeftColumn" -->
    <div id="leftColumn1">
      <?php require_once("pages.php"); ?>
    </div>
    <div id="content">
      <!-- InstanceBeginEditable name="MainContent" -->
      <?php echo((isset($WA_gallery_test_2_1298852612389))?$WA_gallery_test_2_1298852612389->Body:""?><!-- InstanceEndEditable -->
    </div>
  </div>
  <div id="footer">Powered by <a href="http://www.webassist.com/solutions"  title="PHP scripts" target="_blank">WebAssist</a>
</div>
</div>
</body>
<!-- InstanceEnd --></html>
Dave BuchholzBeta Tester
Mike,
it's this part of the code that is causing the issue:
action should be a url parameter i.e. $_GET['action'] or a variable i.e. $action or a recordset row value or anything else that is defined, action on it's own as you have it there is what is causing your syntax error
MikeH
Hi Dave
Thanks for that my fault for assumming that by typeing action it would add it as $_GET['action'].
I did find though that it still messed up a couple of opening and closing or the <?php ?> tags but once I corrected those all works really well.
Thanks again for your help.
Mike
no worries
