Register & Login User at the same time
We need to redirect a user to a protected page after they Register, so we need to log them in at the same time. Any help is appreciated...
On the registration page, edit the insert record behavior and remove the redirect.
then add an authenticate user behavior to the registration page, make sure the authenticate user behavior code comes after the insert record code.
Thank you. That worked. Only weird behaviour is the reg page still redirects to the previous page - not the 'success' page in the login user behaviour. Any ideas?
Please send a copy of your page, I cant have any ideas without seeing the code.
