Can't add any WA tools to the favorites bar
Why can't any WA extensions be added to the favorites menu/bar in Dreamweaver?
I have no problem adding web assist behaviors to the favorites bar.
Right click the favorites screen, select customize favorites.
from the available Objects list, select web assist.
Select the behavior you would like to add, then click the double arrow button to move it to the favorite Objects list and click OK.
Thanks Jason,
But I am full aware of how the favorites work ... been using it for 14 years. And as you will see in my screenshot, WA does not exist as a choice.
Brad
Hi Brad
I do not use the favourites but I have cheked mine and I have the same as you no WA as choices.
Mike
Just for your info, I have WebAssist showing in just the same way as Jason suggested.
Win 7 64bit
CS5
Brad, what version of Dreamweaver?
What is your OS?
What WebAssist Extensions are installed.
I was not trying to say that you didn't know how to use the favorites, only that I cannot recreate the problem.
In DW CS5 and windows 7 64 bit.
I will say that in common with Brad I have several other non WA extensions installed and of WA I have them all installed and all the latest versions.
I do not use favourites but if it helps Brad but knowing what I have installed in common thought I would post.
Mike
Just tried this on my Win 7 system in DWCS5 and have no issues with the favorites.
My first thought is that one of the one WA extensions installed is causing a conflict. try disabling the none WA extensions in the extension manager and testing the favorites again.
The screen shot shows what should be there as I have the WA Tool bar selected.
I am using Windows 7 64-bit with Dreamweaver CS5 (with all updates). All the WA extensions are also up to date.
Have you tried disabling the non Web Assist extensions?
I have tried this in DWCS5 and CS5 on my Windows 7 64 bit system and cannot reproduce the issue.
