login
before purchasing, trying to see if the username field will be an email address or a combination of letters, numbers, characters. Also, is there a requirement as to combination of letters, length of letters, and minimum amount of letters.
Thx
Thx
security assist allows you to elect the username column from your database table.
you can set it up to use the email address column as the username, or any other column in your users table.
security assist does not force any password complexity, but you can use the server validation of Form Toolkit to force password complexity on the registration page if you like.
