No editor shown
I made a page with and placed a content editor using "HTML editor 3" Please take a look at :
index.php an please tell me why the button bar is not showing. When I try it on a local machine there is no problem !!!
Michel
Michel
have you uploaded the entire webassist directory to the remote server? most likely some of the files from the webassist folder are missing on the remote server.
Yes I have uploaded all the webassist file to the remote server.
what version of PHP is your host running? It needs to be php 5 or greater.
Yes the version of PHP is 5
phpinfo.php
what happens if you delete the ckeditor/.htaccess file on the server?
Hi Jason,
Yep that was the trick, the editor now showing
ok, that .htaccess file is needed for the file manager to function properly though.
For some reason, that .htaccess file was causing "Error 500" server errors trying to access any files under the CKEditor folder, you should contact your host to determine why the htaccess file is causing problems on the server.
it is only trying to add an XML Document handler, and should not be causing issues:
AddType text/xml .xml
