DataAssist made plugins not loading
Thread began 2/21/2011 6:43 pm by Jordan | Last modified 2/22/2011 8:42 am by Jason Byrnes | 1002 views | 1 replies |
Jordan
Hi, I seem to have come into a problem with Framework Builder. When I have made the pages with DataAssist, I save them to a plugins folder. They all work from within this folder and connect with the database perfectly fine.
The issue is when I use Framework Builder to insert these as plugins to a page. The page will not load up in my localhost.
I am not sure what the issue could be, however I was getting the same issue with DataAssist pages until I followed the fix you provided from the download centre. I am wondering if it is the same thing, because it seems to be happening with the same pages again.
They work on their own, but unfortunately not with Framework Builder.
Does anyone maybe have a solution to this?
Thank you.
Is the page loading as a blank p[age?
If so, that means a php error is occurring, but error reporting is turned of.
add the following code at line 1 of the page to turn error reporting on:
error_reporting
(E_ALL);
once we know what the error is, we may be able to determine the cause.
