Login errors
Thread began 2/19/2011 12:30 pm by Sally | Last modified 2/19/2011 6:34 pm by neilo | 1173 views | 3 replies |
Sally
Login errors
PG was working fine the last time I did anything with it. Now I went to add a pic and on the login page (at the top of the screen) it says:
Warning: fopen(Connections/installed_gallery.txt) [function.fopen]: failed to open stream: No such file or directory in /data/25/2/98/45/2424045/user/2657060/htdocs/spyglasscondos/powergallery/admin_gallery/images/installed.png on line 15
Warning: filesize() [function.filesize]: stat failed for Connections/installed_gallery.txt in /data/25/2/98/45/2424045/user/2657060/htdocs/spyglasscondos/powergallery/admin_gallery/images/installed.png on line 16
Warning: fread(): supplied argument is not a valid stream resource in /data/25/2/98/45/2424045/user/2657060/htdocs/spyglasscondos/powergallery/admin_gallery/images/installed.png on line 16
Warning: fwrite(): supplied argument is not a valid stream resource in /data/25/2/98/45/2424045/user/2657060/htdocs/spyglasscondos/powergallery/admin_gallery/images/installed.png on line 18
Warning: fclose(): supplied argument is not a valid stream resource in /data/25/2/98/45/2424045/user/2657060/htdocs/spyglasscondos/powergallery/admin_gallery/images/installed.png on line 19
Warning: mysql_free_result(): supplied argument is not a valid MySQL result resource in /data/25/2/98/45/2424045/user/2657060/htdocs/spyglasscondos/powergallery/admin_gallery/global.php on line 37
Then when I submit the login info, I get :
Warning: Cannot modify header information - headers already sent by (output started at /data/25/2/98/45/2424045/user/2657060/htdocs/spyglasscondos/powergallery/admin_gallery/images/installed.png:18) in /data/25/2/98/45/2424045/user/2657060/htdocs/spyglasscondos/powergallery/admin_gallery/index.php on line 58
Thankfully the slideshows still work on the user's side, but I can't admin. Any help would be appreciated. Thank you.
Sally
neilo
Hi Sally,
Could you try replacing your existing /powergallery/admin_gallery/images/installed.png with the one zipped and attached to this post, and see if that resolves the problem?
installed.zip
Sally
Yes that fixed it!!! Thank you - I was just thinking that it's too bad I'll have to wait until Monday for support when I got the email that you had replied to my post. What a pleasant surprise!
I didn't change the image file so I don't know why it suddenly became problematic, but thank you for your prompt reply and fixing it!
neilo
Cool, glad you got it sorted!
