adding another table in WHERE clause on results page
Thread began 2/18/2011 10:46 pm by this_is_me | Last modified 2/22/2011 10:29 am by Jason Byrnes | 1527 views | 3 replies |
this_is_me
I use several related tables, like wine and region. I want to dsiplay the region on the wine results page. So, the foreign key in wine is just a number. IN CS5 my changes are kicked out if I close the changed recordset.
The original recordset is:
SELECT wineID, wgID, wineName, winePrice, weinPic, changed, sort
FROM wine
ORDER BY sort ASC
what I intend to do is:
SELECT wine.wineID, wine.wgID, wine.wineName, wine.winePrice, wine.winePic, wine.changed, wine.sort, region.rgName, region.docID
FROM wine, region
WHERE region.docID = wine.wgID
ORDER BY wine.sort ASC
in order to display the region's name on the results page instead of its id.
But when I click on OK, the rcordset is turned to its original state.
Even if I edit the recordset by hand its turned back again on save. I don't know if this is a DW issue or if it has something to do with DA...
any idea?
this_is_me
Is this unknown?
Am I the only one with this problem?
DarylBeta Tester
I had been having these same issues too, but only in the recordset builder. When I changed the query in code view it seemed to save it.
I have no idea of a fix I'm afraid.
Is the page based on a template? this may be a Dreamweaver template issue. Try detaching it form the template.
Or is the page set to be read only? check the file directly in the Operating system using the Finder for mac or windows Explorer to make sure it is not set to be read only.
