redirect to login using page manager
Thread began 2/17/2011 2:04 pm by lightwalkercreations361768 | Last modified 2/18/2011 7:10 am by Jason Byrnes | 853 views | 1 replies |
lightwalkercreations361768Beta Tester
Dear WebAssist,
When I use the SA page manager and select the redirect if login fails to the login.php it show /login.php, When I select a page that is two or three folders from the site root the page manager still give me /login.php when I select the login page for the redirect if fails.
What is happening is if I go to that page for the first time it tries to redirect to a login page in the same folder as the page, which does not exist as the login is at the site root.
What am I doing wrong, should I be using absolute URL for the login i.e login.php
or is there a better way
many thanks for your help
it should be creating the redirects using document relative paths in the code:
WA_Auth_RestrictAccess("../visitors_LogIn.php");
or:
WA_Auth_RestrictAccess("../../visitors_LogIn.php");
I just tested this on my system and the paths are being creted correctly using DW CS4 on Mac OS, What Dreamweaver version are you using? And what is your OS?
Can you double check the code, is it using a document relative path?
Can you send a copy of one of the pages?
