SQL syntax error data assist 2.08
Thread began 2/16/2011 4:39 pm by randyw2394710 | Last modified 2/16/2011 5:01 pm by Jason Byrnes | 733 views | 1 replies |
randyw2394710
the client_users_Detail.php created with data assist has this error
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'Link, Comment FROM client_users WHERE UserID = 1 OR ( -1= 1 AND UserID= -1)' at line 1
i attached the page
same error for update
client_users_Detail.zip
the error is caused by using spaces when naming the columns in your table, for example:
Web Site Link
spaces should be avoided when naming your column, i recommend using the camelCase naming convention to avoid spaces in the column names:
webSiteLink
