Progress Bar Not Counting Through Emails
Thread began 2/15/2011 8:06 pm by Lee Firth | Last modified 5/21/2015 5:13 pm by Ray Borduin | 2396 views | 7 replies |
Lee Firth
I have applied a progress bar to a universal email newsletter app I am working on. In my test situation there are 3 emails to be sent. They send OK but the progress bar looks like the attached file and doesn't change while sending the three emails. Here is the form code:
html:
<div id="form1_ProgressWrapper">
<form name="form1" action="newsletter_builders.php" id="form1" method="post">
<fieldset>
<ul>
<li>
<label for="Subject">
<input name="newsletterID" type="hidden" id="newsletterID" value="<?php echo $row_newsletter['fldNewsletterID']; ?>">
Subject:</label>
<input name="Subject" type="text" id="Subject" value="<?php echo $row_newsletter['fldSubject']; ?>" size="45" readonly="readonly">
</li>
<li>
<input name="back" type="button" class="btn_back" onClick="window.open('newsletter_bea_to.php?newsletterID=<?php echo $_GET['ID1']; ?>', '_self');" value="back">
<input name="submit" type="submit" accesskey="n" class="btn_send_combined" id="submit" value="send" />
</li>
</ul>
<?php if(is_null($row_newsletter['fldContent'])) { echo '<p>&nbsp;No content exists for this newsletter.<br /><br /></p>'; } else { echo $row_newsletter['fldContent']; }?>
</fieldset>
</form>
</div>
<div id="form1_ProgressMessageWrapper" class="blockUIOverlay" style="display:none;">
WADFP_SetProgressToForm('form1', 'form1_ProgressMessageWrapper', WADFP_Theme_Options['WAUE:Pacifica'], 'newsletter_builders_Universal_Email_1_Progress_2');
</script>
<div id="form1_ProgressMessage" >
<?php require_once("webassist/progress_bar/newsletter_builders_Universal_Email_1_Progress_2.php"); ?>
</div>
</div>
This is the contencts of webassist/progress_bar/newsletter_builders_Universal_Email_1_Progress_2.php
html:
<div id="progressContainer_newsletter_builders_Universal_Email_1_Progress_2">
<div id="progressMessage_newsletter_builders_Universal_Email_1_Progress_2">completed <span id="current_newsletter_builders_Universal_Email_1_Progress_2">0</span> <span id="total_newsletter_builders_Universal_Email_1_Progress_2"></span></div>
<div class="barLeft_newsletter_builders_Universal_Email_1_Progress_2"></div>
<div class="barMiddle_newsletter_builders_Universal_Email_1_Progress_2" id="barArea_newsletter_builders_Universal_Email_1_Progress_2">
<div id="barCover_newsletter_builders_Universal_Email_1_Progress_2" class="barProgress_newsletter_builders_Universal_Email_1_Progress_2"></div>
</div>
<div class="barRight_newsletter_builders_Universal_Email_1_Progress_2"></div>
<div id="timeRemaining_newsletter_builders_Universal_Email_1_Progress_2">&nbsp;</div>
</div>
I'm not sure what the problem is.
Lee Firth
This issue was fixed by my other issue regarding the "To" advanced properties "not sticking".
showthread.php?t=18922
Ok, glad to hear it is working, the issue with the To address will be fixed in the next update to CSS Form builder 2.
this_is_me
I have the same issue with the counter still
The counter is stuck and shows exactly the same picture. Do I have to change the order of the include file?
It could be file permissions on the server webassist/email folder. It keeps track by updating an xml file that it may not be able to create. It could also be an issue with a javascript error. I'd check into the permissions on that folder first... give them 777 and see if that fixes it.
If you still have issues I'll need to look at the page and probably get FTP access to debug.
this_is_me
directory tree not shown on remote server
Thanks Ray,
There were three problems, actually
1) the file permissions solved it partly, but not really. In the end it showed 1 of 1, remaining 1 second. There were 3800 mails in the loop an the counter stayd frozen - nothing was counted and no remaining time was shown.
2) There was another issue which made the whole thing unusable: I had entered Wait 1 second after each mail and set the maximum time to 400 emails every 10 minutes (Once Per Entry). But it fired them out all at once, which created more than 7000 error messages in the email_log database, all with the same message: "Too many connections". I first did a test with 8 email addresses only, but of course it sent them out OK
3) I had entered tu use UTF-8, which was not passed on to the system, so all the European letters cam out wrong. I had to hard-code it into the file PEAR_Mail_using_SMTP_php.php.
One last remark to file permissions: The host uses Ubuntu server, which behaves similar to Debian. It means that the server uses its own user / group called www-data:www-data for APACHE which is different from the ftp user/group. It has great advantages because files can be secured towards ftp access, but they are also immune towards changes done via ftp file permission settings. There is an interface though, where I can change the user/group
It is waiting the 1 second between sending. It appears permissions is still the problem. It can't create the xml file. It looks like you may have uploaded a local xml file which is why it was showing 1 of 1... When I deleted the xml file from the ftp it wouldn't re-create it.
I think the permissions have to be set to 777 for the webassist/email folder, they are currently still 755.
this_is_me
Thanks - it is counting now
I put all files and folders of webassist/email/ to 777 and it works now. Maybe this was an overkill but it works, so thank you
