Can I do this is Cookies Tool Kit?
Thread began 6/26/2009 2:10 am by james261375 | Last modified 7/20/2009 1:29 am by Twist | 3231 views | 4 replies |
james261375
Hi
I have a client with some pdf downloads on his website and he wants users to fill in an enquiry/registration form before they are taken through to the download page.
This is simple enough for me to do but if a user comes back to the link to the downloads they will obviously have to fill in the form again.
Will Cookies Toolkit work so the site will know if a user has filled in the form already? and if so how do I do it?
Thanks in advance.
James
Yes cookies toolkit would be used for something like this.
You would set a cookie when they fill out the form and use the behavior onLoad "go to page if cookie exists" to skip that page when the cookie associated with already filling it out exists.
james261375
Hi Ray
Thanks I'm just putting this together and I have a couple of questions.
Do I need to set the Set the Cookies Value or Store the form in a Cookie and if so what sort of details do I need.
And then once I have a cookie on the Redirect, which I have set on the Body tag, what is the value that I have to set.
Are there any tutorials on this? I've found the remember me samples which seem to be the nearest but I'm still having problems.
Thanks in advance.
James
There should be a behavior "redirect if cookie exists"
You can set a cookie onsubmit of the form and then use the onload event to check if the cookie exists and redirect to the second page.
Twist
Worked a treat - thanks Ray again for all your help.
Cheers
James
