Access rules trouble. Need to only allow access if both rules are true
Thread began 2/08/2011 12:19 am by lightwalkercreations361768 | Last modified 2/22/2011 9:53 am by Jason Byrnes | 1778 views | 6 replies |
lightwalkercreations361768Beta Tester
Dear WebAssist,
I have been reading on the forums to try and find a solution. I thought my problem may have been that I had an extra line by accident in the groups manger, but I don't, I then checked to make sure that my sessions were be created correctly which they are. My problem is that I need to only allow access if both rules are true.
such as MemberProductID IN group 'All_IC'
AND ProgramPartID = 1
if either of these conditions are false I need access denied, but if they are both true then access is granted.
How would I be able to do this? I have included my HelpersGroupsRulesPHP.php file.
Many thanks as always for your help
HelperGroupsRulesPHP.php.zip
you will need to create a separate rule for each condition, then merge them by hand when you apply the access restriction to the page, for example:
if ((WA_Auth_RulePasses("Rule 1")) && (WA_Auth_RulePasses("Rule 2"))){
WA_Auth_RestrictAccess("login.php");
Thank you Jason,
I can do the same with SA show region as well.
Many thanks
Yes, you can.
Many thanks again, that's great
Dear Jason,
I am not getting restricted using the example code you gave me and I am not sure why:
if ((WA_Auth_RulePasses("Feast")) && (WA_Auth_RulePasses("JourneyAll"))){
WA_Auth_RestrictAccess("http://curalarge/login.php");
If I use the code example with my access rules names I get no login needed, the page load even if I do not login. If I change it to this
if ((!WA_Auth_RulePasses("Feast")) && (!WA_Auth_RulePasses("JourneyAll"))){
I get a redirect to login, but when I log and it takes me to the page it allows access because the first rule is true but the second is not.
The "Feast" rule allow access for ProgramPartID = 2 or 99
The "JourneyAll" rule allows access for ProgramID = 3 or 4
When I login my ProgramPartID session is 99 and my ProgramID = 2 which should not allow me access.
I have included my rules page. Many thanks again for your help.
try using this instead:
if ((!WA_Auth_RulePasses("Feast")) || (!WA_Auth_RulePasses("JourneyAll"))){
