Ecart error
I'm getting the error
Dynamically - related files could not be solved because the site definition is not correct for this server . Retry | Setup.
pleas help i'm new t the ecart stuff and i'm pretty lost
By no means am I an expert, but are you getting this error in the top of the Dreamweaver view in a golden bar?
If so that is related to your server setup and not eCart specifically.
If you are using a local server like xampp, you need to setup your testing server as a separate server and make sure you use "localhost".
Steve
see the learning resources page for details on configuring your Dreamweaver site for dynamic development and installing a local testing server if you need more information:
resources.php
