Reporting a bug
Hello webasssist i found a bug that can be reproduced this bug not only affects digital file pro but almost ever webassist extension, steps to repropduce the bug
I created a site in my test server cvalled lomos
so it would be lomas/
Then i used css sculpture to make the css for this site and it created a folder called "lomos_image"
i decided to keep using this folder for rest of the images, so i start building the site with data assist then css form builder
si i create a folder called lomas to place all the admin stuff, so when using the digital file pro to upload images in the admin section on the directory where the file will be placed it should be
../lomas_image/banners/vertical/
but when selecting with DFP i notice even selction the right folder it adds an incorrect folder placing
image/banners/
it eats the ../lomas_ and also the vertical/ example on the steps on the images i uploaded
Step 1:
Selected file for image upload lomas_images
Step 2
Selected inside lomas_images the folder banners notices it says selected lomas_images only and not banners folder on the buttom but at the top where it says select has the correct folder
Step 3: i created there a new folder called vertical and then selected that folder
we can notice now on the top select it says vertical but on the buttom select says: banner
Step 4: after acepting it displays the wrong folder settings and i have to add them manually for the script to work
if we check the upload folder it says i just selected images/banner and i have to place it manually ../lomas_images/banner/vertical/
