Login Problems
When I try to login into my PowerGallery install (index.php) I get the following errors:
Warning: fopen(Connections/installed_gallery.txt) [function.fopen]: failed to open stream: No such file or directory in /hermes/web04/b1996/pow.geldridge/htdocs/gallery/admin_gallery/images/installed.png on line 15
Warning: filesize() [function.filesize]: stat failed for Connections/installed_gallery.txt in /hermes/web04/b1996/pow.geldridge/htdocs/gallery/admin_gallery/images/installed.png on line 16
Warning: fread(): supplied argument is not a valid stream resource in /hermes/web04/b1996/pow.geldridge/htdocs/gallery/admin_gallery/images/installed.png on line 16
Warning: fwrite(): supplied argument is not a valid stream resource in /hermes/web04/b1996/pow.geldridge/htdocs/gallery/admin_gallery/images/installed.png on line 18
Warning: fclose(): supplied argument is not a valid stream resource in /hermes/web04/b1996/pow.geldridge/htdocs/gallery/admin_gallery/images/installed.png on line 19
Warning: mysql_free_result(): supplied argument is not a valid MySQL result resource in /hermes/web04/b1996/pow.geldridge/htdocs/gallery/admin_gallery/global.php on line 37
Warning: Cannot modify header information - headers already sent by (output started at /hermes/web04/b1996/pow.geldridge/htdocs/gallery/admin_gallery/images/installed.png:15) in /hermes/web04/b1996/pow.geldridge/htdocs/gallery/admin_gallery/index.php on line 6
