Email errors
Thread began 2/02/2011 6:34 am by CraigR | Last modified 2/03/2011 7:21 am by CraigR | 1714 views | 5 replies |
CraigRBeta Tester
Email errors
Hi
One of my very first uses of UE.
I can successfully send a message a fixed recipient, but when i get the email address from a recordset, i get the following error...
Warning: fopen() [function.fopen]: Filename cannot be empty in /.../mailformatting_php.php on line 128
Warning: fread(): supplied argument is not a valid stream resource in /.../mailformatting_php.php on line 129
Warning: fclose(): supplied argument is not a valid stream resource in /.../mailformatting_php.php on line 130
can you send your page please and a copy of the webassist/email folder so i can examine the code.
CraigRBeta Tester
thanks Jason.
Files attached
files.zip
CraigRBeta Tester
OK thanks.
if it helps, i am using the CSS form builder extension recommended for use with html editor 3.0.0, which is used in my contact form
CraigRBeta Tester
i started again from scratch and am not getting the same error.
i have managed to send emails to multiple (3) recipients, but cannot as yet personalise them, to include the first name from a recordset.
i wil have another go
