Links being removed by HTML editor
Thread began 2/02/2011 4:06 am by info395053 | Last modified 2/02/2011 8:28 am by Jason Byrnes | 1184 views | 2 replies |
info395053
I have a problem with links being removed by the editor. When I add a link and then check the link via the link function window, the link field is empty. When I check the code, the link looks like this:
<a>Link here</a>
href has disappeared!
Do you know what the problem might be?
Thanks in advance.
info395053
I think I've solved the problem. It was because the html on the page was corrupt - broken tags,sloppy tables etc. When I re-wrote the page into a new file, with cleaner code, the links worked fine.
Thanks.
OK, glad to hear this is resolved.
