WA Rule Manager or Server Behaviour?
I'm using a SA created login page that if successful, redirects user to an index.php page which is populated from recordset1 based on a session id.
I also want to 'show' a couple of lines of text on the same page based on recordset1, where the session name 'id' has called the correct user record and where the session name 'verified' = 0, and not if = 1
By the way, the same page is also inserting the value 1 into the 'verified' field in my sql table if the session name 'verified' = 0
I've tried both WA Region Rules and server behaviours but neither appear able to distinguish between my 0 or 1 in my verified filed in my sql table.
I'm assuming the session names are assigned before the value is inserted??? Could the recordset be running after the value is inserted perhaps??
Advice welcome,
Paul
