Error Initializing Add Form UI - HELP!
Thread began 1/31/2011 11:12 am by combss421855 | Last modified 2/07/2011 7:32 am by Jason Byrnes | 4838 views | 7 replies |
combss421855
I'm new to the WA SS and am trying to use the Form Builder. I've been having problems all day but have been able to resolve most of them via other threads and other common problems. HOWEVER a new one just popped up and I can't find anything on it.
I opened my php form (I had previously made with FB) and tried to "Edit Form" at which point I got the "Error Initiliazing Add Form UI: Reference Error: theServerLanguage is not defined" message. It wants me to add a whole new form which I do not want to do. It also won't let me actually use anything IN form builder now, like it's locked up??
I've tried restarting, I've deleted my .dat file... nothing seems to be working. HELP!
Also - on an un-related note, how can I pop this form built on a php page into my xhtml page? I'm new to PHP and have been very confused by everything I've found online.
AND - when I design it in the preview it shows up as a 2 column form, when I view it in DW CS4 it's a 2 column form, however when I open it in my browser it's a standard one column form... HELP!
Thanks!!
this issue should be fixed in the CSS Form Builder 2.0.1 (HTML Editor Compatibility Release) that is available on the form builder download page.
combss421855
Css fb 2.0.1
I do not use the HTML Editor. Do I still need to download this?
yes, in addition to fixing HTML Editor compatibility problems, it fixes the error you are reporting.
combss421855
Problem came back
I know we just went through this yesterday, but I'm having all the SAME PROBLEMS again today.
However, the solutions I used yesterday ARE NOT HELPING. I am currently trying to re-install this html editor you recommended and it's not installing. It's been "installing extension" and making no progress for the last 45 minutes.
In addition to this I'm experiencing new javascript errors developing from my FB Form. It was working perfectly then I tried to edit the form and it all just broke down.
Now my DW CS4 won't even open!!!!!!
HELP!
nhtmedia421890
I'm experiencing the same issue of spending a day tracking down fixes and now the CSS Form Builder is not working.
Jenn
you reported this issue in another thread as well, see my reply there:
showthread.php?t=18720
