installation problems with security error
Thread began 1/26/2011 1:35 pm by caryn191788 | Last modified 1/31/2011 10:29 am by Jason Byrnes | 2517 views | 11 replies |
caryn191788
Hello,
I use the same powerCMS code to install each website and each time I get different error.
I have followed the thread below on SecurityAssist problems but I was unable to find a solution.
index.php
Warning: Cannot modify header information - headers already sent by (output started at /mnt/Target01/332078/550185/www.physiciansweightlosshouston.com/web/content/powerCMS/Connections/localhost.php:12) in /mnt/Target01/332078/550185/www.physiciansweightlosshouston.com/web/content/powerCMS/WA_SecurityAssist/Helper_PHP.php on line 67
I was trying to access the admin page to login to insert content.
I have added two attachments for review for the WA_SecurityAssist/Helper_PHP.php
& the WA_SecurityAssist/HelperGroupsRulesPHP.php
WA_SecurityAssist.zip
the headers already sent error occurs if there is output between php tags.
the error is being reported at line 12 of the Connections/localhost.php
make sure that there are no blan lines in this file after the closing php tag ?>
caryn191788
localhost error message
Jason,
I do not understand your post:
this is the localhost.php file:
# FileName="Connection_php_mysql.htm"
# Type="MYSQL"
# HTTP="true"
$hostname_localhost = "mysql5-10.wc1";
$database_localhost = "550185_pwlchouston";
$username_localhost = "550185_pwlch";
$password_localhost = "5P5h0y1s8i5c";
$localhost = mysql_pconnect($hostname_localhost, $username_localhost, $password_localhost) or trigger_error(mysql_error(),E_USER_ERROR);
there are not 12 lines only 10.
caryn191788
solved one problem
Hello,
I am not able to login to the admin panel : admin/
when I go to "insert content"
I get a broken page: contents_insert.php
Its the 404 error page without a style sheet.
What can I do to improve so it will proceed to insert information.
Thank you,
caryn
this is a case sensitivity issue.
in the PowerGallery database, double check the remote root setting.
Make sure it is /powerCMS/ with aa lower case p instead of /PowerCMS/
caryn191788
case sensitive link is WA code
Yes I get the problem with case sensitive issue. Except this is not my part to code it is built in to the code I downloaded from webassist.
If you go to the log in screen > log in > then click on INSERT NEW CONTENT > the page that renders is ::
contents_insert.php
So just to make sure I took the above link and changed the PowerCMS to powerCMS and I get the same error.
So I am thinking it is something else and maybe you could really help me this time. Once again its Friday afternoon and I would liket to finish this project so I can start on another one.
Thank you,
Caryn Maus
404 Error Page_Physicians Weight Loss Houston_888-614-6393.pdf
did you look in the wa_settings table of the power gallery database?
in the wa_settings table of the power gallery database, what is the remote root setting?
make sure it is /powerCMS/ and not /PowerCMS/
caryn191788
Jason,
I am setting up a powerCMS not a powerGallery. I did not see any file that references WA table settings.
Please advise.
Caryn
sorry, i meant to type Power CMS, not Power Gallery.
you will need to access the database directly using your host control panel, they should have a program like PHPMyAdmin that you can use to access the MySQL Database.
in the mysql database for PowerCMS there is a table named wa_settings, you need to make sure the PCMS Remote Root setting is /powerCMS/ and not /PowerCMS/
caryn191788
myPHP admin
OK, I guess we are going to play forum tag until I get it. I guess I will cancel my appointment with my client to teach her how to do this at 9am.
I hope I don't get fired.
Attached is a copy of a screen shot of myPHPadmin > there are only two table content and contenthistory.
Not sure what I am supposed to changed. I am not a programmer that's why I use scripts and extensions to be easy and offer clients items they can work without paying exorbitant rates to a programmer.
Thank you,
Caryn
