Multiple Content Areas Allowed?
Using Site Sculptor can I define multiple content areas? I have a template with a left and right column.
Tom
Tom
when the site design is created from the template, the menu region will be converted to a CSS Menu writer menu and the rest of the editable regions will be converted to CMS content areas.
Thanks for the quick reply (again!), I just wondered because it only asks for navigation, content and footer in the site design even though I defined several editable regions, am I doing something wrong?
T
the conversion of the other editable regions will need automatic, not something that you select.
