CMS 102 and HTML Editor 3
HI I mainly use the CMS 102 for most of my sites if I upgrade to HTML Editor 3 is it just a case of replacing the HTMLEditor folder with the new one when I create new sites?
Regards Alistair
Regards Alistair
You would have to update the html editor code on any page you want to use the new editor. It should just be a matter of making sure you use the same editor name and default value. You may also have to clear out your old kfm tables from your database since some people are reporting they aren't getting updated when installing over a previous version.
i asked the same thing in the pcms area alistair
showthread.php?t=18415
jason gave some details...i haven't had a chance to try it out yet though
