Error at step 2 of Security assist wizard
Thread began 1/23/2011 7:01 am by bob.barker225207 | Last modified 1/26/2011 12:42 pm by Jason Byrnes | 2380 views | 6 replies |
bob.barker225207
Mac 10.6.6 using Dreamweaver CS5
While Executing OnClick in SecurityAssistWizrd.htm javascript error:
At ine 1350 of the file .......: SecurityAssistWizard.js
App-OBj.currentSkin has no properties
I have reinstalled Security Assist several times and I have cleared the cache file each time.
The error persists.
Later the same day ....
Deleted the cache, remove all extensions, deleted the cache, installed all extensions, deleted the cache. ran dreamweaver, exact same error at step 2 of wizard. I also get the same error regardless of which table I point to. All of the tables work with the site.
What is wrong with this expensive extension?
I saw this same error several times in the forum with no resolution please advise fix.
Note the cache has been cleared, so do not suggest it as a fix.
In your set definition, in the servers tab, do you have a testing server or only a remote server? if you have only a remote server, set it to be the testing server as well.
On the first step of the SecurityAssist Wizard, are you selecting to use a template? If so try without a template.
can you send a screen shoot showing the selections being made on the first step ?
bob.barker225207
Security Assist error at Step 2
1. I am using both a remote and testing server
2. I am not using a template
Note also that on this Mac system, everytime I invoke security assist in Dreamweaver, it asks me to enter the registration details for security assist. If I log out of Dreamweaver and restart it, it asks again for the registration details.
Note that on a Mac laptop at same loacation, with Dreamweaver, accessing exactly the same servers, site and Mysql database, the wizard works.
So I assume it is something wrong with the Dreamweaver set up on the main system, but since everything else is working fine, I am reluctant to reinstall Dreamweaver.
Any thoughts?
Are there any special characters in the Macintosh Hard Disk name? or in your user name? special characters may b contributing to the issue.
bob.barker225207
Security Assist Wizard
The server names, user names, everything in fact uses alpha characters only, no spaces, no special characters.
As another clue, I get a similar error on this system when using Data Assist. Both Data Assist and Security assist work on my Mac Laptop using Dreamweaver against exactly the ssme server, test server, database, user, everything.
bob.barker225207
More data
Here is the page 1 and 2 screen.
Why does it require me to reactivate this sucker everytime that I use it?
