checkbox = tinyint?
is tinyint the correct choice for a 0,1 check box? or bit or bool....
using check box for "send me an email when account due?" they would check the box meaning "yes" or "1". unchecked means "no" or "0".
using mysql
thanks
David
using mysql
thanks
David
Yes that is the way I would do it, sample line from one my admin table sql set up files
`publish` tinyint(1) NOT NULL DEFAULT '0' COMMENT 'Publish Option (0 = Unpublished, 1 = Published)',
