Activation and Serial Number
Thread began 1/18/2011 2:04 pm by clinton178625 | Last modified 2/02/2011 3:27 pm by Jason Byrnes | 3187 views | 5 replies |
clinton178625
Hi Guys
I accidentally put the wrong serial number into a new installation and now i get a failed log in error how can i put the correct serial in without having to uninstall and install everything all over again? because i cannot access the admin now to change it?
Cheers Clinton
the serial number is stored in the Power Store database in the wa_settings table. You can also find the Admin username and password in that table.
The serial number will not effect login, if you are having an issue with login, first make sure you are not using special characters like a double quote in the username or the password. If there is still an issue, use the session test page from the following post to make sure the servers session management is working correctly:
showpost.php?p=23826&postcount=2
danielsebas
Hi Jason, for what is the serial number? I updated from sitesculpture to PowerCMS and everything is working ok but an error that is shown at the bottom of the Home tab
Warning: mysql_free_result(): supplied argument is not a valid MySQL result resource in /home2/dsmusicn/public_html/site2/admin_cms/common/load_content.php on line 125
and in settings I have the option of adding the serial number but is blank
What version of MySQL is the Host running, It will need to be mySQL Version 5 or above. also, the Version of PHP will need to be PHP version 5 or above.
danielsebas
Hi Jason, I am using MYSQL 5.1.47 and PHP 5
