Can't Log in to Power Gallery
I go to the root directory of Power Gallery in my browser and I get this error:
Warning: require_once(WA_Globals/WA_Globals.php) [function.require-once]: failed to open stream: No such file or directory in /home/content/o/n/e/onetooneweb/html/cpc/PG123/index.php on line 1
Fatal error: require_once() [function.require]: Failed opening required 'WA_Globals/WA_Globals.php' (include_path='.:/usr/local/php5/lib/php') in /home/content/o/n/e/onetooneweb/html/cpc/PG123/index.php on line 1
If I go to the admin_gallery directory then I get this error.
Warning: mysql_free_result(): supplied argument is not a valid MySQL result resource in /home/content/o/n/e/onetooneweb/html/cpc/PG123/admin_gallery/global.php on line 37
Warning: Cannot modify header information - headers already sent by (output started at /home/content/o/n/e/onetooneweb/html/cpc/PG123/admin_gallery/global.php:37) in /home/content/o/n/e/onetooneweb/html/cpc/PG123/admin_gallery/index.php on line 6
I have attached the global and index files below. Thanks
