Side menu doesn't link
Thread began 1/14/2011 10:53 am by mick106153 | Last modified 1/24/2011 11:26 am by Jason Byrnes | 2062 views | 5 replies |
mick106153
Starting a new PS4.01 site and the side menu reflects the main menu but doesn't display any of the choices made there.
Instead I get the following…
"Page Not Found
We cannot locate the page you are looking for. Please check the address and make sure all letters are lowercased with no spaces. You may also move to a different page by using the links in the menu bar above."
Any choices made in the main menu work as expected.
Only 2 faux products entered so far - I'm still building the categories.
index.php
Choosing as an example - Products/2013 Enlistment/Enlisted - gives the following result…
products_results.php?Search=1&ProductCategoryID[]=40
regardless of whether you choose it from the main or side menu but the side menu gives the error shown above.
Mick
the side menu links will try to load the products_results_xml.php page:
products_results_xml.php?Search=1&ProductCategoryID[]=39
this does not appear to have been uploaded. Please make sure the products_results_xml.php page is uploaded to the server.
mick106153
Thank you Jason!
Saved me again.
Is it usual for something like this to happen - to arbitrarily choose to not upload a file?
Mick
Dreamweaver's FTP program can be a bit flaky at times.
I would use filezilla or another dedicated FTP program for large uploads to the server.
Dreamweaver is OK for small uploads, but even then, I dont trust it as far as I can throw it to uploading correctly.
dave276887
same issue here
I have products_results_xml.php already uploaded so that file is not the issue.
site is amtcgear.com.au
and it is only in categories with more than 10 items that the next button does not work.
Any solutions??
It looks like you have found the fix for this in the known issues section of the power store download files, i dont see the issue when i visit your site.
