checkout
I am trying to checkout what i have in my cart but the checkout button keeps linking me to the same page I'm on. How do I check out the items i have put in my cart?
Did you use the checkout wizard to create the checkout pages?
Are you seeing this problem on the cart page? or on the checkout page?
I have used the checkout wizard to create the pages, but the checkout button is not linking me to the checkout page and the View Cart button is not linking me to anything either. they keep redirecting me to the page i am currently on. The clear button works though.
Sounds like a php error on the page.
Add the following code to line 1 of the page:
error_reporting(E_ALL);
ini_set('display_errors');
be careful not to copy any surrounding spaces or create blank lines between code block when pasting the code or you will create other errors.
Post back with any errors that show on the page and a copy of your page in a zip archive so i can examine the code.
I added the code to line one of the page i am having trouble with, uploaded that with all the errors in a .txt document. Thank you!
change line 1 -10:
//WA eCart Include
require_once("WA_eCart/OnlineStore_PHP.php");
//WA eCart Include
also you're if statements are causing errors,
for example:
$page=page12;
if($page==page7)
is not valid code, it should be:
$page="page12";
if($page=="page7")
values and string comparisons must enclosed in quotes, you have a number of if statement like this that are causing errors.
