Framework breaks jquery accordian
Thread began 1/12/2011 3:33 pm by Daryl | Last modified 1/12/2011 5:05 pm by Jason Byrnes | 928 views | 5 replies |
DarylBeta Tester
I have a page http://isldecorating.com/services.php that contains a plugin of a jquery accordion.
Within this plugin is a gallery (Pretty Photo) as a plugin.
The combined result is for the accordion to be broken.
If I remove the gallery plugin, everything works as it should.
Can anybody help please?
the fire fox error console shows the following error:
Error: jQuery("#jQueryUIAccordion").accordion is not a function
Source File: services.php
Line: 198
Looking at the source code, there are a couple of thisngs that jump out at me that may be the cause of the problem.
This is invalid markup for a div tag:
<div div style="display: none">
and the closing </html> tag is not fully formed it is just:
</ht
DarylBeta Tester
Hi Jason
I have removed the div that you mentioned (I was trying to hide all but the first thumbnail).
I have also corrected the closing html tag in services.php, however this still does not resolve the issue.
fire bug is still giving the same error, so there is something wrong in the page somewhere that is causing the javascript to break.
I'm not at all sure what it is. since the page is added using the framework, i would suspect that there is something in the main page that is breaking it.
I would strip down the main page to the bare bones to get the jquery working, then start building it back up.
DarylBeta Tester
the Jquery works if I only include the accordion plugin, but not if the gallery plugin is in the accordion plugin.
so then there is a compatibility issue between the accordion and the gallery.
this sounds like more of a jquery issue.
