Password Verification
Thread began 1/07/2011 10:12 am by rufus406794 | Last modified 1/18/2011 12:41 pm by Jason Byrnes | 3093 views | 10 replies |
rufus406794
Is it possible to have the form check a database to verify the password is correct?
I would like to give (control) the password to the user… before he registers.
He would then use the password when registering.
When he submits the form, the form would check the database, if good he would gain entrance if not he would be rejected
Can you help put me on the path?
Many Thanks for a Great product and support!
the only way to do this would be disable the registration form for the users since you would need to basically do a simple registration for them to enter the password that is used for their email address.
then when they login using the email and password you register for them with, they can update the rest of the profile.
rufus406794
Ok that may be a little much for me…
What I am trying to do is limit a new register for having access to some protected pages.
Just because someone registers should not mean they have access to all pages.
What would I need to do to…
Add a few fields to the users Profile page and add a submit button.
This way once they register I could login and place the link on their page.
I just purchased Securityassist and Universal if that will help.
Thank you for Any Help
sounds like you want to have user level authentication.
the user would be given limited privileges on registration, then you could elevate their level.
see the user level authentication tutorial in the solution recipe section of the security assist support page:
securityassist/
rufus406794
I found the answard showthread.php?t=13734&highlight=Email+Verification
It is where you remove remove the verify email code so that the user does not get the verification link. Then only users that you manually verify will be allowed.
rufus406794
Please... Can you tell where I can find this to remove?
...remove the verify email code so that the user does not get the verification link...
if you do not want to send the registration email, delete the following code block from the registration page:
if ((($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST)))     {
//WA Universal Email object="mail"
  //Send Loop Once Per Entry
$RecipientEmail "".((isset($_POST["UserEmail"]))?$_POST["UserEmail"]:"")  ."";include("WA_Universal_Email/WAUE_users_Registration_1.php");
//Send Mail All Entries
if ("users_ThankYou.php"!="")     {
header("Location: users_ThankYou.php");
rufus406794
Sorry but that is not what i need...
I only want the admin... to receive the email saying that someone reg. and to verify this email address.
when i do that you suggest, it kills any email being sent... admin does not receive an email letting him know some one reg... so how would i know if someone did reg.
Please, what do i need do so only the admin receives an email with the click here to verify
thanks
change this line:
$RecipientEmail = "".((isset($_POST["UserEmail"]))?$_POST["UserEmail"]:"") ."";include("WA_Universal_Email/WAUE_users_Registration_1.php");
to the admins email address:
$RecipientEmail = "admin@yourdomain.com";include("WA_Universal_Email/WAUE_users_Registration_1.php");
rufus406794
Works.
Thank you for Great Support...
