Fix right istalled??
I copied the FIX into the folder I should.
Now, when I say, Only Images, to JPG 100%
and then, RE-Enter the Upload Behavior.
It flips back to 80%
Did I something wrong?
Denis
Denis
It doesn't keep the value properly when inspecting. This is a bug.... it will use the correct setting you can see in the code, it just always says 80% when you open the interface.
ahh, ok, I thought that was fixed with that fix... :-)
Cheers and greets from sunny cologne!
Denis
That will be fixed in the next dot release. The fix was a quick fix in the code to address the default value problem. We will have an official update for both pretty soon.
Great!
an dont forget the CROP thing :-)
