Trouble inserting multiple records using data assist
I need to create an insert form that will retain primary user data for multiple record entries.
IE... a user would enter name, employee number one time,
then, using the repeat region... specific details (up to 30 records) such as date, time, details are entered into the database as separate records on a single 'insert'.
Goal: The database would contain one record per date without requiring the user to retype repetitious user data.
I have the insert form set up and data is flowing into the database. The issue is that the repeat region/insert multiple records is inserting into a single record using the 1,2,3 format (that is, data entered into the repeated fields is being grouped as a single entry, rather than creating three separate records).
HELP! I'm still using Dreamweaver 8 and am wondering if that may be a part of the issue. I've attached a file for your reference.
